[Carminat Navigation Informé 2] Carminat Informé 2 - cnI2 - enable aux
Hello,
Sorry that I cannot write in French.
I'm looking for help to ENABLE AUX on the CNI2 Radio.
I have a Megane 2 / 2007 with a Carminat Radio + Navigation + CDC
I want to keep the CDC and enable AUX. Is this possible ??
If so what do I need to buy, and which pins do I need to connect?
This is the radio + cdc:
http://i57.tinypic.com/r9n05s.jpg (image trop grande)
http://i62.tinypic.com/zxwd91.jpg (image trop grande)
thank you!
Message Mar 14 Avr, 2015 11:04
There is no AUX on CNI2.
If you want to add it, you have to remove 6-CD charger, and replace it by a charger emulator. As AudioConnexionBox or Xcarlink.
Ok Thank you.
Also, A Switch cable would not work either? to switch between ACB / CDC?
something like this: http://fr.aliexpress.com/item/Car-MP3-CDC-Switch-Cable-Fo..anger/591142749.html
If the above thing will not work, might it be possible to connect AUX (Audio Left / Right / Ground) ONTO the wires of the CD changer.
burn a empty track on a CD - put it on repeat and then use the mp3 / aux cable to play when the CD is playing?
Message Mar 14 Avr, 2015 15:04
The CD charger is Digitaly connected to the CNI2. Can't be wired as you describe.
The link on "ali-thing".. is for VW.. not for renault.
Message Jeu 03 Aoû, 2017 15:08
Hello. I have CNI2 but without CD-Changer. Can I put AUX-in?
