nicolas a écrit: Bonjour !
Est-il possible de rajouter le système de surveillance de la pression sur une Laguna qui n'en est pas équipée ?
D'après la doc elle devrait l'avoir mais finalement non. A priori ça ferait partie des équipements supprimés au même titre que les anti-brouillards avant par exemple
Donc est-ce que l'achat de 4 valves et un passage à la valise diag pourrait permettre d'activer et donc rajouter ce système ?
Hello from Russia! Sorry for the bad translation - used translate.google
May be completed with TPMS
Here are the steps you need to do
1. connect the clip to the car, and as is usually included with the native wine and carry out a multiplex network test
2. Exit / closing clip
3. in a folder in the installed program (for me it was the drive C: \ CLIP_X91 \ Data \ User \ DSDD _ ***, *** where the current version of the clip (in this folder stores the history of all the settings / use of the clip, go necessarily in the current version installed in the laptop) find the folder with VIN cars
4. Go to the folder with the desired VIN in cars
5. see file mtc.xml
6. open it with any editor (eg open a built-in editor "Notepad")
7. find SDPRPN
8. delete the letter S is not touching anything else (to become DPRPN)
9. without touching the rest, save the edited file
10. Start the video as usual
11. go to the UCH (645) and sign in repair mode
12. The left menu has a "button", "Operations provided before / after repair" (I do not remember the name, but I think the essence is clear), you press it
13. Insert the disk reprog
14. There is a line in the documentation Activate SC042 (Automatic Configuration) press it
15. answer a couple of questions bend (not always asks) and the desired configuration is loaded from disk reproga
16. Check that the configuration block "function, tire pressure monitoring" has become a "C" (along with the others look, they should remain unchanged, the change should only be a function of the control tire) (on the instrument panel lights up red placards possible with the inscription "ERROR PROG "because there is a mismatch settings dashboard and UCH in repair mode, the dashboard will be visible mismatch error programs)
17. If you became a "C" (and it clearly became C
if done as described) need to enable control tire tidy - to go to the section of this configuration the instrument panel and in the function of monitoring tire pressure instead of "NO" to choose " C "and save the configuration
18. You can start the program the sensors (for example, by lowering the pressure optimally to do together, one looking at the screen "Clip" -a second pulls the wheel)
19. The wheel pump up to 2.5 - 2.7 cups twirling not leave for 5 minutes (for "calm" sensors)
20. Enables programming sensors
21. Get down, the "Clip" th wheel until the green "light" that the sensor has registered, we run to the next (because time is limited, and if the process drags on, the procedure is "fly" on timeout and will have to do first ).
22. restore the pressure in the wheel, watching the screen tidy that it is the right tire pressure changes (sensor "vereschit" not only the trigger pressure, but also to a sharp rise)
23. I say thank you
ps
Pressure sensors 407000435R
