MULTIFUNCTIONAL TUNE POINT
The Multi-functional TunePoint will enable you to connect your personal music player to the radio of your Renault. Use either the USB or jack to connect and control your personal mp3 player using the fingertip remote controls on the steering wheel.
The TunePoint is available as standard or option on most Renault models including Twingo, Wind Roadster, Clio III, Mégane III, Scénic III, Laguna III, Espace IV, Trafic II, Master III.
Contact your dealer
It should be noted that it is not compatible with vehicles equipped with Cabasse radio CD players or a CD changer.
UPDATE YOUR MULTI-FUNCTIONAL TUNEPOINT AUDIO SYSTEM
Please read our instructions carefully before updating the software.
TunePoint audio settings
1. Know which version is installed:
In the vehicle, turn the radio on, Source: FM
Go to the menu « Settings » (last button, bottom right on the stereo face)
Select the menu « Audio Settings »
Select « USB connection version »
Select « Display the software version »
The screen will show a message like the following:
s2.42m2.42 => you have the latest version
other => software update recommended
2. To update the software, you need:
1 USB key
3. Download the latest version from your computer:
Save the file on your USB key (do not save it in a folder)
Unzip the file and make sure it is saved in the root of the USB key
Take the USB key to the vehicle
4. In the vehicle:
Turn the radio on, « Source: FM »
Plug in the USB key
The radio will automatically update its source
Go to « Settings > Audio Settings> USB connection version > Update Software »
Wait approximately 1 minute (the time to download), during which time the music will stop, without touching the radio and without attaching / unplugging anything
Once the update is finished, go back to « Source USB » and the music should re-start
